FATAL ERROR : Unhandled Access Violation Reading 0x0018 Exception at e7ed8492h
Dear community friends,
I have received a DWG file with couple of objects inside. I opened the file, made a copy of one of
the object , then saved the dwg file. All went OK. Then i tried to open the same file with changes  I've
made inside, i am unable to open the file. Error message is : FATAL ERROR : Unhandled Access Violation Reading 0x0018 Exception at e7ed8492h, and AutoCAD closes itself.
Any idea where can be the problem ?
Never had an issue before like this with any drawing.
I have AutoCAD LT 2011. Sender sent me the file in new versions than 2011 but he also sent me the same file
saved in 2006. Behavior is same...
Thanks for answer...
Viktor
jayhar
You received file is corrupt file, click here How to repair corrupt AutoCAD files.
or
Open new cad file > Insert the drawing into a blank drawing as a block and then explode.
or
Visit here
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly. If your issue persists,
Please give me a bit more detail on this issue so we can continue to work towards getting this solved.
Thanks You
Jayhar.M.J
Helpful Links: Prepare your computer for download |  Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
