Windows 7 - 64 bits receiving multiple fatal errors during the day:
FATAL ERROR: Unhandled Access Violation Reading 0x0000 Exception at 5fa187abh
Anyone have a solution for this?
Welcome to the Autodesk Forums!
New problem?
Any Windows updates? Especailly .NET updates?
Waht changed on the computer recently?
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Has been going on for a couple of weeks now, no Windows updates in that period.
So you're saying the fatal error is caused by running LT2006 on Windows 7 64 bits, or is that an assumption? Before I start looking into a solution like Longbow, I would like to make sure it's a compatibility error.
Uninstall the AutoCAD LT
Autodesk Recommended Clean Install Procedure:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?linkID=9240817&id=2887771&siteID=123112
Uninstall all .NETS and C++ on the computer.
Reinstall the LT 2006 using XP emulation mode and as an Administrator on the System
Open AutoCAD LT 2006 as an administrator and activate. Does it run?
My Auto Cad LT 2006 (running on Windows 10 in compatibility mode for Windows XP SP 3) had been trouble free but began giving the same Fatal Error today when I clicked on the "open" icon.
Specifically: "Unhandled access violation reading 0x0000 exception at 5fa187abh"
In another, more helpful string, there was a similar issue on Windows 7 solved by updating the display adapter driver.
I updated the display adapter driver and the issue was solved.
This post was intended as a potential answer and not specifically as a reply to pendean, but as a new member i clicked on the wrong button.
Bill
