Hi @Simon.hull.09,
sorry to hear you have such trouble.
May I ask which printer you use for the PDFs? Have you tried another one? And could you please give me some more details on your configuration? AutoCAD version and OS. Have you ever used PDF printing? Did it ever work?
The more details you give me the better I can understand your situation and might help.
You could also check out these Articles
Crash or hang when plotting to 'DWG To PDF.pc3' in AutoCAD
Fatal error when plotting to Adobe PDF from AutoCAD
Maybe you can find some useful information there.
But anyway, keep me updated.
Thank you
Hi Simon,
I haven't seen an update on your post or answers to Sofia's questions so I thought I would check with you to see if you resolved your issue in printing PDFs.
If not, please tell me which printer driver you are using. I suggest for a test that you stick to one of the AutoCAD PDF drivers such as AutoCAD PDF (General Documentation).
If this still crashes, please also check to see that your file has no errors using Audit and Purge.
Next i would (believe it or not) check to make sure your video drivers are current.
Please gave me an update so that I or Sofia can continue to assist you in fixing the issue.
