- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I hope someone can help with this - I've seen several queries on the web by users with similar problems and, mostly, they don't seem to get resolved. My issue is that lines in some layers of a drawing plot very light when plotted using the Autocad PDF printer. I have played around with line weights and transparency settings in model space and paper space and tried ACAD.CTB, None and Monochrome.CTB, none of which seem to make any difference.
It's only in certain layers and not everything in the layer is faint, for example text is fine. There's a block in the drawing made up of five lines and a circle and one line prints fine, but the rest don't. This is a block that repeats seceral times in the drawing and it's the same for all of them.
I found today that the drawing plots okay from model space using DWG to PDF print driver, so suspect it's something to do with paper space. I did get a "the annotation scale is not equal to the plot scale" warning when printing from model space, but can't believe this has anything to do with it?
Would appreciate some help, as this is holding me up issuing drawings for a project I am working on.
I can send example of PDF and original DWG file.
