AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Error - writing 0x0024 Exception at 76dbe4e4h while DWG to PDF
6 REPLIES 6
a1301199221
589 Views, 6 Replies
I have odd problem with writing DWG to PDF. When I do that, Autocad breaks on 'Sending sheet to ploter'. Then error message apperas
(0x0024 Exception at 76dbe4e4h). I found that only empty sheet is writeable. How to solve this problem?
AutoCad 2013
Windows 7 64-bit
I'll be grateful for any help.
6 REPLIES 6
a1301199221
in reply to: a1301199221
I installed Service Pack 2 for AutoCad 2013 and now I don't have any error while writing DWG to PDF, but created PDF files are not openable. I saw the status of progess of writing to PDF and I perceived that it finished after 'Sending sheet to ploter'. Problem is still not solved.
pendean
Which PDF driver are you using?
a1301199221
in reply to: pendean
I'm not sure if you mean this.
pendean
Good, that's the one we all can use too.
Does the crash happen with all your files? Or just this one?
2013 is not new: so has this just started happening?
a1301199221
This problem concerns every single drawing and is in existance since first use. I tried alternative Polish program, similar to this, called 'dopdf' and it works properly. That's why I think it's problem with drivers, used in DWG to PDF.
pendean
Your driver may be corupt then: works fine here. Replacing it invloves removeing and reinstalling LT AFAIK unless this other driver is a viable option for you.
”Boost
