I have odd problem with writing DWG to PDF. When I do that, Autocad breaks on 'Sending sheet to ploter'. Then error message apperas
(0x0024 Exception at 76dbe4e4h). I found that only empty sheet is writeable. How to solve this problem?
AutoCad 2013
Windows 7 64-bit
I'll be grateful for any help.
I installed Service Pack 2 for AutoCad 2013 and now I don't have any error while writing DWG to PDF, but created PDF files are not openable. I saw the status of progess of writing to PDF and I perceived that it finished after 'Sending sheet to ploter'. Problem is still not solved.
This problem concerns every single drawing and is in existance since first use. I tried alternative Polish program, similar to this, called 'dopdf' and it works properly. That's why I think it's problem with drivers, used in DWG to PDF.
