Error 1625 for MaterialLibrary2020CM
When installing version 2020 of autocad LT sometimes i have the error 1625 ( capture )
this happen with the installation of MaterialLibrary2020CM
The msi log : MaterialLibrary2020CM.log
it's not an admin right issue ( admin account )
Any Ideas ?
natasha.l
Hello @Anonymous,
Manually installing the Materials Library then repairing the installation should resolve this.  Please follow the steps below to try & resolve this issue,
  1. Temporarily disable security settings like Antivirus, Firewall & UAC on your Windows operating system
  2. Locate the C:\Windows\Temp\AutoCADLT_2020\Img\Content\ADSKMaterials\2020\CM\MaterialLibrary2020.msi
  3. & try to install it manually. If you receive an error please reach out your IT Admin for higher system permissions Error 1625.
  4. Windows Start > Control Panel > Programs > Uninstall a Program > Autodesk AutoCADLT > Uninstall/Change > Repair or Reinstall > Repair
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Ok I find a solution :
Browse to HKEY_CLASSES_ROOT\Installer\Products\
Browse through and find your product. Delete the key relating to your product and this should allow the application to install.
