ERASING A SINGLE COLOR ON ONE LAYER
lacee_perry
Message 1 of 8
lacee_perry
Hi there. I have a one layer drawing that includes multiple different colors. Is there a way to "select all" blue in the layer to erase, rather than having to individually select each blue object?
Replies (7)
Message 2 of 8
pendean
Community Legend
Community Legend
@lacee_perry you have QSELECT, FILTER or SELECTSIMILAR commands to use to pick only those blue items, then you can use PROPERTIES command to change that color. Is that enough? Or is there something else going on perhaps.
Online tutorials:
https://thecadgeek.com/blog/autocad-select-similar/
https://allaboutcad.com/use-quick-select-to-select-objects-in-your-autocad-drawing/
https://www.youtube.com/watch?v=hhL8d6K6tZA
https://help.autodesk.com/view/ACDLT/2023/ENU/?guid=GUID-1B3F02ED-3C98-4FB6-889A-197B2830106F#:~:tex...
Message 3 of 8
cadffm
Sure, you can select objects by type or properties (like color) by command
QSELECT <- this is the best choice for your task
FILTER
SELECTSIMILAR (its not the right choice here, because you need to setup)
OR
SSX
Sebastian
Message 4 of 8
lacee_perry
This definitely helps me with most of the issue. Now that I know how to "select all" blue, is there a way to specify individuals to exclude? Example: I have a 1000 peg hole grid on my drawing, and I want to "select all" to save time, but really need 4 of them to stay in place. Is there a way to "select all, but not these 4" etc...?
Message 5 of 8
h_s_walker
When you have done the select all, hold down the shift key and then select the 4 you want to stay. This deselects them.
Howard Walker
Left Handed and Proud
Message 6 of 8
cadffm
You should really learn the main basics fast as possible (there are usere who doesn't know them, still after decades),
Read about it and TEST IT in a sample DWG, until you understand how they works.
OBJECT SELECTION methods
Type in: SELECT<Enter>[F1]
OBJECT SNAP methods
Type in: OSNAP<Enter>[F1]
Sebastian
Message 7 of 8
lacee_perry
Thank you so much! I am going to go try this out. If so, you just saved us hours of work each month!
Message 8 of 8
lacee_perry
I would love nothing more than to learn all the ins and outs of the program. We were forced to take a crash course with a tutor because we had to switch CAD programs quite quickly (previously using FastCad). Just trying to navigate my way through in the meantime until I can dive in further later. The book for dummies has been helpful. lol
