Dynamic door block with attribute
YoshiCoolen
YoshiCoolen
Hello everyone, I made a handy door block.
However, the attribute gives the wrong info.
I want the attribute to show the door width.
In this block he gives the wall opening.
But I don't need that information.
h_s_walker
What I would do is add a line between the door frame and add that to your door width stretch and use a field to reference the length of that line OR
Just add a dimension to the door width, and add it to the stretch and hide all non relevant lines. If you do that the distance will update in real time instead of you having to regenerate it.
Howard Walker
Left Handed and Proud
YoshiCoolen
Wow @h_s_walkerthis was already very helpful.
Since sometimes I don't have the patience to regenerate.
But if I rotate the block, the measure will automatically change text direction. Is it possible to turn off the text direction?
h_s_walker
Post the updated block so we can have a look at it
Howard Walker
YoshiCoolen
The updated block.
cadffm
Offtopic:
You should re-create this block, this time: CLEAN length&coordinates.
Especially for Blocks, Layouts and other kind of "templates" you should spend some time more,
becaue you will use it often in the feature.
[F1] LUPREC / AUPREC
Sebastian
h_s_walker
@YoshiCoolen See the image below (red ringed items).
If you want the El text to stay horizontal I would add the text to the dimension text
Howard Walker
