DXF For Laser Cutting Has Too Many Line Segments - Laser Head Shakes
Alright so, here's my issue that the company I work for has faced for quite some time. We take on these custom logo laser cutting jobs a lot. We have a 10' x 5' Mazak Fiber Laser. So these are often large jobs cutting steel.
I am the engineer on staff so I prepare the artwork, often received as a PDF, into a DXF. I do this usually by auto-tracing the image in Inkscape or by manually drawing it in SolidWorks if the shape is too blurry or complicated. I then export that image as a DXF.
The problem is, if there is text or other objects that have arcs and such in them, they turn into hundreds, if not thousands, of tiny line segments. These can be cut on the laser, but it will rattle the head back and forth to trace the lines out. We do not want that. Now, I could go back and use the features in SolidWorks such as arc and spline and replace all of these and make it work. But, this takes hours of time that basically outweigh the profit we would gain from the job itself. I have been trying to use AutoCAD LT to turn the lines in splines, but selecting them all individually and converting them to polylines, then to splines, takes longer than just going back and drawing arcs for everything.
There has to be a faster way. I am a novice in AutoCAD, so please be explicit in your descriptions.
Thank you.
