DXF file too big
DXF file too big
DXF file too big
I've got Autocad LT for mac.
I've got a laser cutter that requires DXF files.
I drew up a very simple object using dynamic input - all squares on a single layer. - that measured 147mm x 88mm.
I saved as a DXF.
I tried opening this file in my Laser cutter software and got the message ' File too big dimensions : 17812.04mm x 12772.52'
Can someone shed any light on what is happening?
Does anyone know if Autocad is a suitable application for drawing up files for a laser cutter, or should I bin it in favour of something else?
This is trial software for 30 days. Support and tutorials seem non-existent so unless things start making sense soon. I won't be buying.
cadffm
Open drawing.
command -LAYER
thaw *
on *
command ZOOM
extents
Is your drawing full screen display now?
if not:
command: ZOOM previous
command WBLOCK Option Object selection -> choose your Objects.
Test the new File
Sebastian
steven-g
Could you post both the dwg and the dxf, see if someone can see what is happening, are you sure there aren't any other objects in the drawing
pendean
Community Legend
Community Legend
See your other post.
