dwg file size increase each save
first im sorry for my bad english, currently i have few version autocad LT 2011,2012,2013,2014 and i found out the when i save the dwg file size will keep increase even i dont do any changing. It is possible different version autocad cause my problem? *currently i save file of types using autocad2010/lt2010 drawing *dwg
cadffm
1. Check ISAVEPERCENT
2. Every Program version have to store the native data information when you save in older dwg-versions.
   (not for every object type, but for some)
And working with older DWG version:
Every open a file acad have to convert the data, every saving acad have to convert the data.
It should not be problem between 2010-2012 with dwg2010 and between 2013-2017 with dwg2013.
If your file size is blowing up more than 200% it could be a issue, under 200% it is possible.
Sebastian
pendean
Community Legend
Community Legend
After you set ISAVEPERCENT to 0 (that's a zero)... read this post for additional tips http://www.cadforum.cz/cadforum_en/size-of-a-saved-dwg-file-grows-unexpectedly-tip9739
jayhar
Hi
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/AutoCA...
Please upload Cad file
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
