Dots Instead Lines When LWDisplay Open
ugur_salur
Observer Observer
ugur_salur
Observer
Observer
Hi all,
I draw a line with Line, Polyline, Rectangle, any command. I turn on the Lineweight display property. But as the lineweight gets thicker, the line is replaced by the start and end point. How can i see my thick lines? Thank you.
pendean
Community Legend
Community Legend
@ugur_salur Have you installed the 2022.1.3 / 2023.1.4 / 2024.1.2 Update yet? You never mention which year version you are using so I am listing the three newest.
ABOUT command will confirm what you have installed. If not, get it from your Autodesk Account Page here https://manage.autodesk.com/cep/#products-services/updates
Restart your PC afterwards.
If that did not help... Set GFXDX12 variable to 0 (that's a zero) then restart AutoCAD/LT20xx: reverting to DirectX11 fixes similar problems for most users.
Also consider turning off LINESMOOTHING and LINEFADING variables
If still no relief then start GRAPHICSCONFIG command and change the 2D Display Settings pulldown from "advanced mode" to one of the other choices.
HTH
CGBenner
@ugur_salur  Did the information provided by @pendean answer your question? If so, please use Accept Solution so that others may find this in the future. Thank you very much!
Chris Benner
ugur_salur
Observer
Observer
"If still no relief then start GRAPHICSCONFIG command and change the 2D Display Settings pulldown from "advanced mode" to one of the other choices."
This ones works. Thank you 🙂
gtmayna
Community Visitor
Community Visitor
Had a user install AutoCAD 2023 and experienced this issue for existing drawings on their machine.  Tried this and it fixed the issue.  Thanks!
