dimensioning
dimensioning
dimensioning
In older versions, when dimensioning or drawing lines, I had a little window that popped up that showed the length of the line as I moved the cursor.  For instance, if when using the line command, I clicked on a wall and then dragged the cursor to another wall, it would tell me what the distance is.  I'm sure that is still an option for 2019 LT, but I can tfigure out how to turn it on.  Any help is appreciated.
Sean
h_s_walker
Sounds like you've accidently switched off dynamic mode.
At the command line type DYNMODE and change the value to 1
Howard Walker
Left Handed and Proud
Bob_Zurunkle
Isn't that F12 or something?
If by some odd chance my nattering was useful -- that's great, glad to help. But if it actually solved your issue, then please mark my solution as accepted 🙂
Thank you Bob.  That did it.
