Design Center?
Design Center?
KeithSWD
Message 1 of 10
Design Center?
KeithSWD
I am used to 'Design Center' in full Autocad, but am now using Autocad LT 2023.  I need to copy a set of layouts between drawings and would normally use DC for this but I cannot find it.
Ctrl-2 - brings up the Blocks palette (this is not the DC I know...)
AdCenter - unknow..
I have seen articles relating to Autocad LT suggesting I find it under Menu - View - Palettes (no such menu entry)
I have looked at the Tools and Window menu lists and it's not there either.
I just looked at Autocad LT 2022 and it's also missing in that version.
Has it been dropped from the product?  Any other ways to get a set of layouts from one drawings to another?
thanks
Replies (9)
Message 2 of 10
h_s_walker
I doubt designcenter has been removed.
Have you tried at the command line just typing ADC and then pressing return?
Howard Walker
Left Handed and Proud
Message 3 of 10
cadffm
Sorry, but you are not running AutoCAD LT 2023, you are running AutoCAD LT 2023 FOR MAC
ACAD MAC Forum is over here  https://forums.autodesk.com/t5/autocad-for-mac/ct-p/4051
You can try command LAYOUT to import your Layouts (untested, I am not a MAC User)
https://help.autodesk.com/view/ACDMAC/2020/ENU/?guid=GUID-A6D40A6B-D65C-4368-9650-476CAD3DA0C3
Sebastian
Message 4 of 10
KeithSWD
doh - sorry of course I am...
Message 5 of 10
cadffm
it#s okay, but still *for MAC version don't have the DesignCenter 😕 Try command LAYOUT
[command+2 opens the Content window = Blocks]
Sebastian
Message 6 of 10
KeithSWD
LAYOUT just offers layout options (new,, rename etc.).  It seems MAC version really doesn't have DesignCenter, sadly.
Its manual copy-paste content for me! Thankfully just the one drawing (but with 20 layouts 🙄)
Message 7 of 10
maxim_k
Hi @KeithSWD ,
Try to use "Template" option inside LAYOUT command, it allows to create a new layout based on an existing layout in a template (DWT), drawing (DWG), or drawing interchange (DXF) file.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 8 of 10
KeithSWD
Hi Maxim - thanks for the suggestion, my situation is that I have received a drawing exported from Vectorworks (ie a mess), it has 20 or so layout tabs. I have imported the model space geometry into our standard DWG to pick up styles etc. and I was hoping to import the Layouts with DC as I have done before with Autocad /Windows. But I don't think anything like that is possible with LT for MAC.
Message 9 of 10
pendean
Community Legend
Community Legend
Message 10 of 10
KeithSWD
Thanks Maxim - I hadn't gone far enough with the Template option to see you could import multiple sheets from a DWG file.  Not quite as user friendly as the DC but it works. Or at least it might do when I get the ghastly mess VW export has made of this file!!
Keith
