Default name and location for printed file
MrMuscl3
MrMuscl3
Is there a way to tell AutoCAD LT to automatically use original filename and filepath for printing?
Example: Print file as pdf
File location and name: C:\drawing.dwg
Output: C:\drawing.pdf
This would save time.
AutoCAD 2025
john.vellek
Hi @MrMuscl3,
If you check in OPTIONS, you will see a tab called Plot and Publish.  In that window is a place where you can set your default Plot to File location.
John Vellek
john.vellek
Hi @MrMuscl3,
I am checking back to see if my post helped you with your problem or question. Please mark my post as the solution if it resolved the issue or give me a bit more detail on this issue so we can continue to work towards getting this solved.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
cb94030
I have ACAD LT 2023 and it shows on the top of the screen only the file open. Is there a way to show the whole file path? See attachment.File name.JPG
cadffm
Another topic = another thread
But look at the options too
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2020/ENU/AutoC...
Sebastian
cb94030
Thanks a lot, that's what I was looking for!!!!!!!!!!
