Hi there,
Is it possible to export data from AutoCAD LT in CSV format?
I was using full version of AutoCAD, where I used 'dataextract' command to extract block xy coordinates and block attributes into CSVs. So wondering whether this is also possible in LT version?
If not, are there any extensions / plugins anyone can recommend for the LT version to help achieve this?
Thanks!
Solved by steven-g. Go to Solution.
Nope, nope, nope, dataextraction isn't in the LT tools, LT also cannot use extensions nor can it use plugins. You can use Attext which requires a block with at least one attribute (plus an extraction template file) or you can use the 'list' command to get information from Autocad into Excel. But none of that is automated, what sort of data do you want to get out.
@ntakvarelia - AutoCAD LT does not have native export capability as Steven indicated. However, if you share a little more about what you are trying to export, the community might be able to come up with some workaround.
Attached is an Autocad lt dwg file. I am trying to get the lines out in any format. I can get the data points from the DXF file but I am looking for something easier.
See your other duplicate post https://forums.autodesk.com/t5/autocad-lt-forum/i-want-to-export-line-data/m-p/12376995#M203119
