custom linetypes with text
Message 1 of 45
I am attempting to create a custom linetype with text in it, but the format used to create the line. Which is as follows:         A,.5,-.25,["GAS",STANDARD,S=.1,U=0.0,X=-0.1,Y=-.05],-.25  is not producing the result I need. Asimple linetype is no problem but when I attempt to add text, it wont load into the drawing. I need to create a "gas line" because no matter what I do I can't read the text that is in the default gas line. I have tried any number of things to make the text larger, to no avail. Can anyone help?
Replies (44)
Message 41 of 45
can you please send me that procedure with commands please
Message 42 of 45
can you please tell me how can i edit HW to OFC in hot water supply
Message 43 of 45
h_s_walker
Open up the .lin file in notepad.
Find the linetype GAS
Copy it to the bottom of the document
Change the name and text to OFC
Save the .lin file
Howard Walker
Left Handed and Proud
Message 44 of 45
rlafuenteZMLWV
I am attempting to create a custom linetype with text in it, but the format used to create the line. Which is as follows A,.5,-.2,["4.16kv OHL",STANDARD,S=.1,R0.0,X=-0.1,Y=-.05],-.70. is not producing the result I need. Can anyone help?
Message 45 of 45
pendean
Community Legend
Community Legend
See your other duplicate post https://forums.autodesk.com/t5/autocad-lt-forum/create-linetype/td-p/12204141/jump-to/first-unread-m...
Also, have you tried the tip right above yours yet?
