Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
I purchased a custom font, and installed the file on my computer, and previously was able to use the file on my desktop. Now while working on my laptop I have reinstalled the font but it seems AutoCAD can't find the path. Can someone please help me with this? I have attached a screenshot.
Thanks!
Solved by Thmucha. Go to Solution.
FYI the LT forum is here:
https://forums.autodesk.com/t5/autocad-lt-forum/bd-p/43
Though this question can also apply to AutoCAD
Not sure how your purchased font installation works. It most likely installed onto Windows Font folder. Perhaps try and locate that TrueType font on your desktop and just manually copy that onto your laptop
you alreay rebooted? Let's go
>> installed the file on my computer, and previously was able to use the file on my desktop."
okay
>>"Now while working on my laptop I have reinstalled the font but it seems AutoCAD can't find the path"
If the font is well installed in windows (we are talking about windows OS on a PC ?), the answer is:
You installed another Font (perhaps the same name, but not the same definition!),
compare the Font version!
Windows/Fonts/...find your Font and compare the properties (and share the properties here)
Sample Screenshot of another font:
Sebastian
I got the font designer to send me a different format font, reinstalled it, rebooted and it worked! Thanks anyway guys.
