Cursor is slow, jumpy, or jerky in AutoCAD
robert.gaudreau
robert.gaudreau
The mouse is jerking off, slow to respond, jumpy.
This issue is happening only in AutoCAD LT 2020 on the computer no other program has this problem with the mouse cursor. On the same computer, other programs that uses very large files does not have this jumpy, slow and jerky with the mouse cursor. It is very annoying.
I found this link it did not answer to the problem I’m having with the mouse cursor.
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Cursor...
The computer AutoCAD that is running on
Operating system
Windows 10 Professional 64 bit
Program
AutoCAD 2020 version 47.0.0
Processor
Intel Xeon E3 @ 2.90 GHz 44 °C
Technologie Skylake 14nm
RAM
32.0 Go Single Chanel @ 1063 MHz (15-15-15-36)
Motherboard
HP 80D6 (U3E1)
Graphics
Generic PnP Monitor (1920x1080@60Hz)
DELL U2312HM (1080x1920@60Hz)
DELL P2314H (1920x1080@60Hz)
VGA TO HDMI (1080x1920@60Hz)
Intel HD Graphics P530 (HP)
4095 MB NVIDIA Quadro M5000M (HP) 44 °C
Version ForceWare: 419.67
SLI deactivated
Hard Drive SSD
476GB SAMSUNG MZVPV512HDGL-000H1
I’ll like to know what to do in Autocad to solve the issue.
Thank you
Robert
h_s_walker
Have you got snap to grid on? F9 toggles it
Howard Walker
Left Handed and Proud
pendean
Community Legend
Community Legend
... or turn off hardware acceleration in GRAPHICSCONFIG command inside LT2020.
robert.gaudreau
I appreciate your help; the grid is on; the snap is off; the ANNOALLVISIBLE was on; I disable it did improve the performance a bit, but the cursor still jerky.
robert.gaudreau
Nice to get help, I have turned off the hardware graphics with GRAPHICSCONFIG command. It did not improve the mouse behavior.
pendean
Community Legend
Community Legend
Check out the first handful of links here for things to try (disregard LT versions listed for now, try everything) https://www.google.com/search?q=autocad+lt+2020+mouse+is+jerky
robert.gaudreau
Great link it really helps to narrow down the problem.
By applying these commands the cursor lag and jerky are gone.
What I did is invoking the 3DCONFIG command activates hardware smooth line display.
Here's the link that explains it
https://www.youtube.com/watch?v=giOkkh3fuh0
The other thing also that I've done is calling DYNMODE Command set to 0.
https://www.youtube.com/watch?v=Ba_ynUL6Mgg
Both commands' settings did improve the cursor lagging. With these and the previous solutions, the lagging is gone.
Thank you for your help
