ctb file issue
ctb file issue
Message 1 of 9
ctb file issue
My acad.ctb file is missing.  How do I get it back?
Replies (8)
Message 2 of 9
"Repair" AutoCAD ?
Message 3 of 9
h_s_walker
Are you using ctb or stb files when plotting.
If when plotting the highlighted area in the image below has .stb at the end you're using the wrong file type. If this is the case at the command line type CONVERTPSTYLES and choose YES. Now when plotting again you should see a .ctb extension.
Howard Walker
Left Handed and Proud
Message 4 of 9
pendean
Community Legend
Community Legend
Your DWG file is probably set to STB, not CTB: are all you seeing STB files?
You can use CONVERTPSTYLE command to flip it from STB to CTB format.
Message 5 of 9
The drop down list for the plot style table shows all .ctb files.  However the acad.ctb file isn't listed.  Is it because I'm using AutoCAD LT?
Message 6 of 9
cadffm
No, then the acad.ctb is missing in your plotstyle folder(s).
But acad.ctb is useless, it's the same like plotting without plotstyles or you create a new ctb from the scratch and saveas acad.ctb
Sebastian
Message 7 of 9
Ok, I'll create it from scratch.  Thanks
Message 8 of 9
john.vellek
Hi @Anonymous,
Here is a copy of my CTB file.  It should be placed under your profile folder in a location similar to this one:
C:\Users\,USERNAME>\AppData\Roaming\Autodesk\AutoCAD 2019\R23.0\enu\Plotters\Plot Styles
John Vellek
Message 9 of 9
john.vellek
Hi @Anonymous,
I am coming back to your thread to see if the issue or question you posed has been resolved.  If so, please mark the post or posts as Solution(s) to help others find the answer quickly. If your issue persists, please give me a bit more detail on this issue so we can continue to work towards getting this solved.
John Vellek
