Cross section line
Cross section line
Cross section line
I have just downloaded Autocad LT 2018, I used to be a super user in autocad mechanical 5 years ago, but since then autocad has not been needed where i work, but now we think about getting autocad again.
It seems that the LT version could be sufficient, but due to my time away from autocad i am not sure if the feuture(s) i am lokking for are missing due to the LT version, or if the tap has been moved.
Anyway, I am trying to add a cross section view to my layout, just like the one mentioned here. https://knowledge.autodesk.com/support/autocad-mechanical/learn-explore/caas/CloudHelp/cloudhelp/201...
I have been lokking for a hour or so but can not seem to find the tap.
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member to the AutoCAD LT forum. Welcome to the Autodesk Community!
This appears to be a tool used with a 3D model.  If so, then you will need full AutoCAD instead of AutoCAD LT.  Is it possible to attach a sample drawing so I can verify what you are trying to do?
Here also is a link to a Trial of AutoCAD if you want to compare.
John Vellek
Hi
No I am not talking about 3d, this is actually a really simple feauture 🙂
On below drawing I had to draw the lines ad insert a text box to make the A A cros section on the upper view, and then add below A-A text box above the lower view.
I do belive that there should be tool to create these symbols and lines, and also keep track if one drawing has more than one cross secktion view, A-A B-B C-C etc.
I am aware that I have to draw both views from scratch. It is just the lines, with arrows and automatic created text box I want.
I hope this is more clear 🙂
pendean
Community Legend
Community Legend
That is not a feature in AutoCADLT or plain AutoCAD: REVIT LT has that, REVIT has it, and all the vertical versions of AutoCAD have that.
john.vellek
Hi @Anonymous,
You might consider making a Dynamic Block that looks like this so you don't have to enter geometry manually.  As Dean indicated, this feature is not available in AutoCAD LT.
John Vellek
h_s_walker
Here have some section arrows. You might want to fiddle with the text style of the attributes
Howard Walker
Left Handed and Proud
Thanks for the attachment!!
