Creating & loading custom linetypes
hohlUF7J5
Message 1 of 9
hohlUF7J5
I created new linetypes to an existing .lin file using Notepad, but Linetype Manager does not show the new lines to load. I even created a couple of new linetypes at the end of acadlt.lin as directed and linetype manager still does not show them to load
Replies (8)
Message 2 of 9
h_s_walker
Post a screenshot of your .lin file so we can have a look at what the information is
Howard Walker
Left Handed and Proud
Message 3 of 9
pendean
Community Legend
Community Legend
@hohlUF7J5
1) Which LIN file did you edit?
2) Where was it located?
3) Did you code it correctly? I don't see your screenshot of code.
4) Are you 100% positive LINETYPE command found the LIN file you edited, and not the stock LIN file that you did not edit? You can easily find out in that same pop-up to confirm yourself anytime like this
Message 4 of 9
hohlUF7J5
Here is my file.....changed demo linetype but it does not change on dwg also added LPS linetype:
But when I go to load the file it still only shows the original file that i had from  reg ACAD ........I think the reason is I have a original dwg with these linetypes in it that I opened
should that .lin file be somewhere else? I added LPS and changed demo linetypes using Notepad
Message 5 of 9
hohlUF7J5
Whoops I forgot to post last screen shot
Message 6 of 9
pendean
Community Legend
Community Legend
Message 7 of 9
hohlUF7J5
I think maybe I wasn't clear on my explanation:
My linetype file contains "LPS" linetype which I created (last one in list). When I went to load it into the dwg it did NOT appear in the list. Refer to the previous message.....
Message 8 of 9
pendean
Community Legend
Community Legend
@ hohlUF7J5 Is there a blank line here at the very end of the LIN file? It is required
Otherwise this file is not the one being loaded.
Message 9 of 9
steven-g
Providing you are actually trying to load the correct filename.lin then you should have had an error message telling you there was a problem and then indeed the LPS linetype will not appear in the list.
See the numbers after the U in your image.
it should read U=0.0 and not U=0,0 (decimal point and not a comma)
