>>". but it can print "DWG to PDF" or "AutoCAD PDF" with comment (search in comment). "
This IS the PDFSHX-trick, so it works as designed.
If you need real searchable Text elements, you have to use ttf-Fonts instead SHX (= simple shapes in PDF).
Sebastian
![EESignature EESignature](http://autodesk.i.lithium.com/t5/image/serverpage/image-id/1272565i464DC3DC646B4F11/image-size/original)
