HII
I CANT GET PRINT FROM PRINTER AS WELL AS I CANT CONVERT INTO PDF ALSO GIVE SOME SOLUTION HOW TO SOLVE THIS PROBLEM
Solved by pendean. Go to Solution.
I believe this is the issue you were referring to in your other thread. If you can provide more information it would be very helpful when troubleshooting your issue.
Can you also provide screeengrabs of your issue?
Excusme .
i know how to convert pdf to dwg & vice verse but is your software issue whenever i get print or convert into pdf is always create problem i m not asking that come & teach me at my location and help in my task .its your software issue when i install trail version that time i dont have any problem now its create problem when i purchase license version & whenever i get type plot commnad its show that problem
its showing this error so its not my problem i talk to my IT person he said that mail them they will answer you
So that error message is popping up when you try to plot a drawing? Or when you are trying to create a .PDF? Or both?
Also, just FYI, the vast majority of the people on here are AutoCAD users like you, not AutoDesk employees. People here try to help each other, and if you are trying to contact AutoDesk for formal tech support, try this: https://knowledge.autodesk.com/contact-support/technical-support
still i have problem
Problem signature:
Problem Event Name: APPCRASH
Application Name: acadlt.exe
Application Version: 27.0.52.0
Application Timestamp: 56b6e4e1
Fault Module Name: StackHash_7e72
Fault Module Version: 6.3.9600.17415
Fault Module Timestamp: 5450559e
Exception Code: c0000374
Exception Offset: PCH_36_FROM_ntdll+0x00000000000911FA
OS Version: 6.3.9600.2.0.0.256.48
Locale ID: 16393
Additional Information 1: 7e72
Additional Information 2: 7e72b6c7c3d6ed7a61cc73e901c4fb4a
Additional Information 3: 123c
Additional Information 4: 123cebeb1530d072c766c3c80aa56469
Read our privacy statement online:
http://go.microsoft.com/fwlink/?linkid=280262
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
Did you read and try the solutions Dean posted? What did you try? How did it go?
I click on option command and go to plot and publish and set the printer uses printer default as what I want then apply and ok I try this method
