Combine objects to get just the perimeter
jalkaz
jalkaz
Hello everyone,
I need to draw the outline/perimeter of several objects with a specific distance. Like this for example:
Step 1Step 1
Step 2Step 2
Step 3Step 3
At the moment I use OFFSET, then EXPLODE, then FILLET/ROUND and then I JOIN the lines because I need it to be one polyline. After that I delete whatever lines are left over. Is there a faster way?
Thanks in advance!
pendean
Community Legend
Community Legend
REGION command: use it to convert your closed plines into region-type objects.
Then use UNION command to merge/join the outer Plines (not the "holes") into one shape.
Then use SUBTRACT command to remove the "holes" from your outer now-a-single-object shape.
That's what you want.
Nope, Plines can't have "holes", they are just magic lines, not filled-in shapes.
HTH
jalkaz
This is it. Thank you!
