Colour change on a multiple texts
Hi ,
i wish to change the text colour on a group of texts .I mean on a multiple texts-object tags ,
it shows me on a drawing that those are mtexts, and I can only change colour individually on an each text.
Is there a faster way to change text colour on a multiple texts (object tags)?
pendean
Community Legend
Community Legend
In AutoCADLT, if PRPOERTIES command cannot do what you want, then there are manual overrides inside each MTEXT or attribute. You will need to enter each one through that editor to manually set it to whatever you want.
ChrisPreece
Hi @Anonymous,
I see that you're posting for the first time. Welcome to the Autodesk Community, and thank you for posting your question here in the AutoCAD LT forum.
I'm just checking in to see if you need more help with this. Did the suggestions that @pendean provided work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Chris Preece
Technical Support Specialist
