Cant plot in all black
No matter what I change I can not plot this one drawing in all black.  I have it in Monochrome and edited the monochrome settings to all black, grey scale.  still shows color when print preview and plots in color.
pendean
Community Legend
Community Legend
Are you using CTB or STB plot style tables?
What are you plotting to?
Are the objects autocad colors 1-255 or are they truecolors/RGB colors?
Show us a DWG file with this problem if you feel you are unable to answer these questions.
I have no idea.  Please see file
pendean
Community Legend
Community Legend
So the layers are indeed set to RGB colors:
Simply change them to AutoCAD colors:
Then select all the objects in modelspace and use PROPERTIES command to set the colors to BYLAYER.
Now you can plot with your CTB monochrome option.
Thank you very much.  What does RGB stand for?
pendean
Community Legend
Community Legend
RedGreenBlue, if you notice, the colors are three sets of numbers separated by a comma.
