Can AutoCAD count multiple blocks at once and automatically put it into a table?
kaige_naidooCYGKB
kaige_naidooCYGKB
I understand that it does count blocks individually. Is there a way to specify the count area and have the software count each block and set it into a table all at once?
I have created a system that uses blocks for every type of item the company I work for sells. the count works fine and there are no issues other than having to count one block at a time.
cadffm
[F1] COUNT (and DATAEXTRACTION, but not for a specific area)
Sebastian
h_s_walker
@kaige_naidooCYGKB What version of LT are you using?
If you are using LT2024 explore the COUNT command. See the link below
AutoCAD 2022 Help | Count | Autodesk
Howard Walker
Left Handed and Proud
kaige_naidooCYGKB
Hi Howard I found that the BCOUNT command works best and I am able to create a table from that. I am also able to export the table into excel or google sheets.
h_s_walker
@kaige_naidooCYGKB You can create a table when using the count command in LT2024 as well
Howard Walker
