Block Table throwing Unhandled Exception error
SimonPettitt
SimonPettitt
I am using a block table to recall some parameters based on block vis state.
However, once I've changed one or two cells, it then throws an 'unhandled exception' every time I try to click on another cell, scroll or do anything else - apparently "Index was out of range. Must be non-negative and less than the size of the collection. Parameter name: index"
I'm pulling my hair out because I can't seem to find a way past it to carry on with work.
Has anyone seen this before?
More details:
Application does not support just-in-time (JIT)
debugging. See the end of this message for details.
************** Exception Text **************
System.ArgumentOutOfRangeException: Index was out of range. Must be non-negative and less than the size of the collection.
at System.ThrowHelper.ThrowArgumentOutOfRangeException(ExceptionArgument argument, ExceptionResource resource)
at Autodesk.AutoCAD.AuthoringEnvironment.BlockPropertiesTableDialog.mMainGrid_CellParsing(Object sender, DataGridViewCellParsingEventArgs e)
at System.Windows.Forms.DataGridView.OnCellParsing(DataGridViewCellParsingEventArgs e)
at System.Windows.Forms.DataGridView.PushFormattedValue(DataGridViewCell& dataGridViewCurrentCell, Object formattedValue, Exception& exception)
at System.Windows.Forms.DataGridView.CommitEdit(DataGridViewCell& dataGridViewCurrentCell, DataGridViewDataErrorContexts context, DataGridViewValidateCellInternal validateCell, Boolean fireCellLeave, Boolean fireCellEnter, Boolean fireRowLeave, Boolean fireRowEnter, Boolean fireLeave)
at System.Windows.Forms.DataGridView.EndEdit(DataGridViewDataErrorContexts context, DataGridViewValidateCellInternal validateCell, Boolean fireCellLeave, Boolean fireCellEnter, Boolean fireRowLeave, Boolean fireRowEnter, Boolean fireLeave, Boolean keepFocus, Boolean resetCurrentCell, Boolean resetAnchorCell)
at System.Windows.Forms.DataGridView.OnValidating(CancelEventArgs e)
at System.Windows.Forms.Control.NotifyValidating()
at System.Windows.Forms.Control.PerformControlValidation(Boolean bulkValidation)
at System.Windows.Forms.ContainerControl.ValidateThroughAncestor(Control ancestorControl, Boolean preventFocusChangeOnError)
at System.Windows.Forms.ContainerControl.UpdateFocusedControl()
at System.Windows.Forms.ContainerControl.AssignActiveControlInternal(Control value)
at System.Windows.Forms.ContainerControl.ActivateControlInternal(Control control, Boolean originator)
at System.Windows.Forms.Control.WmSetFocus(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
pendean
Community Legend
Community Legend
Have you seen this similar issue? Fixes are the same for that system level issue, consult your IT folks if needed https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Error-...
SimonPettitt
Thank you! Will contact them in the morning, and come back here with the result.
Cheers
