Block prompting order
How do i get attributes inside a block to prompt in a certain order when you AttEdit a block? I have roughly 20 attributes in a border block that i want to edit in a certain order, b/c it's a pain if they are just random. Thanks
I have LT 09, BTW.
When creating the block, select the attributes one by one in the order you
want them to show up before selecting the remaining block entities.
Dean Saadallah
http://LTisACAD.blogspot.com
thanks
Charles_Shade
Also, from inside the BE highlite an attribute, right click, and at the bottom you'll see attribute order. (That should still be in '09)
You will need to erase the existing instance of the block and re-insert for the new order to show up.
Regards, Charles Shade
I'm using 2009-LT and I've tried several variations of these commands (bedit-battorder-save-erase-purge-insert-etc) as well as the other instructions on this thread w/o success. While the Attribute Order window is in the sequence I want, the Attribute Edit window retains the original sequence. Any more suggestions or am I doomed to throw this block away and start over?
Thanks.
Steve Moss
