Block Attribute Text Justification Reversed
Message 1 of 8
Hi there,
Just wondering if anyone can help. I'm new to Autocad & blocks so this may be super easy but I have an issue:
When I define the attributes for some block input fields I'm finding that when I justify the text 'left' it sits right or if I justify the text 'bottom' it sits top. Same for the opposite is true.
Can anyone shed any light please.
Replies (7)
Message 2 of 8
Can anybody confirm if this is an issue with the project file or my program itself? Thanks.
Message 3 of 8
pendean
Community Legend
Community Legend
Your attributes are all sitting in the wrong spot for your left-center justification, move them: left justified text need to sit on the left of a box you want to keep them in, not the middle (or right like you have the larger ones).
Message 4 of 8
Thanks for your response. I've just read back through my post and can see that I didn't explain myself properly.
There is an option/property where you define the justification for the block attribute.
In my example I have placed the text on a centre point and picked "left middle" justify in the options. What happens in practice is that the program places the text to the right hand side.
If I choose the Top option in the properties the program places it at the bottom.
Cheers.
Message 5 of 8
cadffm
Top, Bottom, Middle left is the base point (justify point) relative to the Text,
changing this property is not changing the XYZ-Position of a Text(or Attributdefinition).
Thats nothing to do with blocks or specialy for attributdefinitions, that basic knowledge
about using the properties palette.
Change of Justify changes the justify, change of XYZ-Position changes the XYZ-Position of the base-/justify position.
But there is also  command to changing the justify property and re-calculating the XYZ-Position in the same time,
command JUSTIFYTEXT.
Sebastian
Message 6 of 8
Understood. Thanks.
Message 7 of 8
pendean
Community Legend
Community Legend
I wonder if you need to use an actual TABLE object for your titleblock side bar, since you appear to want a cell behavior in your text in the squares... .
Message 8 of 8
Now that I understand what the Justify option actually does I can work with that to get my text where I want it.
I've only been using the prog for a month so I'm just getting the hang of things.
Thanks for taking the time to respond/draw the picture.
