BLOCK ATTRIBUTE MIRROR AND ROTATE BEHAVIOR
leoschu_azevedo
Message 1 of 8
leoschu_azevedo
I'm using CAD LT 2022 in my officce and am experiencing some weird things.
For instance - I have this simple block that I use to label some objects. It has a attribute inside it.
When I copy a instance of this block that is mirrored (scale x = -1) using the command COPY it behave as expected and the text copies as it is in the source block. But if I do it with CTRL+C / CTRL+V the text gets mirroed.
And it gets weirder - if I change the Xscale property from -1 to 1 the text stays where it is and the rest of the block rotates 360º around the insertion point.
Any ideas?
Replies (7)
Message 2 of 8
leoschu_azevedo
I've made a screencast with it.
https://autode.sk/3Cfh8Ix
Message 3 of 8
leoschu_azevedo
I've found that the block has a basepoint def. If I remove it the problem is gone... but then all the instances of the block in the drawing flies somewhere since the block wasn't drawn in the 0,0.
Message 4 of 8
cadffm
So the basepoint parameter was the only dynamic parameter in your block... right? Right!
(You talked about a "simple block", but it wasn't. Blocks with dynamic parameteres are "dynamic blocks"
and dynBlocks are other animals)
Basepoint/0,0
Open your block by BEDIT and move ALL objects from <pick your wanted "basepoint">, move it to: *0,0,0
Well done.
(I know what happend, but i don't like to explain in english / but in german if you like 😉 . Short: Thats usual for a very special situation).
Sebastian
Message 5 of 8
leoschu_azevedo
Thanks!
Message 6 of 8
leoschu_azevedo
But actually it didnt solve the problem... even drawing the block in 0,0,0 and without using basepoint parameter.
It still behave in the same odd way.
Message 7 of 8
leoschu_azevedo
following experiences...
https://autode.sk/3ChTcnQ
Message 8 of 8
cadffm
It did solved one problem:
Your (first) Problem was "But if I do it with CTRL+C / CTRL+V the text gets mirroed"
And you found one of the problem (i could have given you the tip also): SOLVED!
>>"It still behave in the same odd way."
This is another problem, but without a real solution.
>>"And it gets weirder - if I change the Xscale property from -1 to 1 the text stays where it is and the rest of the block..."
That's right, changing the XYZ-Scale vom <0 to >0 or the opposite way is not the same like MIRROR command,
the mirror command handle the recalculation of the attribut position, properties-palette(XYZ-Scale edit) not.
We can explain what happen, but we (other users) can not change the program.
Best way, if possible, set your basepoint in the middle - just a workaround for a bit better result.
Sebastian
