Block attribute hyperlink lost after inserting a block
I'm trying to create a blocks for the equipment which I'm working with. Above each block I have created new attribute "TYPE" which is hyperlinked to the datasheet on the website. I'm using attribute instead of text just in case that I need a block without the name above, it can be easier deleted.
This is how I'm creating my block:
- prepare a drawing for my block
- add a new attribute and hyperlinking it
- creating a block
Block1 is ok and it's hyperlinked but if I do the insert block, I don't get the hyperlink (as show on "Block Type").
Hyperlinking text would work, but I would prefer to have it as an attribute.
It's strange also that when I open the block, the hyperlink is there, but is not working when block is inserted.
Anyone has some idea what I'm doing wrong and how to do this properly?
steven-g
The hyperlink works fine when I insert a block in your drawing, can you describe exactly the steps you take?
pendean
Community Legend
Community Legend
In addition to other relies... is HYPERLINKOPTIONS (Command) turned on/set to YES?
I'm inserting a block with insert button / insert command.
I have just checked this on my other pc with Autocad 2021 (full) and it works there.
HYPERLINKOPTIONS (Command) is set to YES in both Autocads..
So, just a small update:
R.47.0.0 AutoCAD 2021 - not working
R.47.0.0 AutoCAD 2021 - working
P.46.0.0 AutoCAD LT 2019 - not working
On two same versions of AutoCAD I get different result, so I guess it must be some setting, it remains to know which one..
