Batch Plotting - how do I choose a printer or set a default printer
Hi All,
I trying to do a batch plot to a printer.
When I go into batch plot, the printer that is chosen is an old printer so I want to print to a new printer (which I have set as my default printer in the PC control panel).
However I can't figure out how to choose the new printer in the batch plot dialogue box.
Any help appreciated.
Thanks.
RobDraw
The page set-up with the printer need to be in the drawings or a named page set-up can be imported into publisher and applied to all the plots.
Rob
pendean
Community Legend
Community Legend
PUBLISH RULE OF THUMB:
1. Launch Publish from a drawing that is not part of the publish set, but is configured with all your possible sheets and plotter options.
2. Bring in all the drawings/tabs to be published.
3. Import the pagesetup desired from the template file (in your case, one set up for exacting desired output).
4. PUBLISH.
RobDraw
Why do you need step one?
Rob
