Batch plotting has started to plot in color- AutoCAD LT
keedesigns
Observer Observer
keedesigns
Observer
Observer
I have autocad lt 2023.  I batch plot all the time and have my plot style saved which is in black and white.  When I print a single page, it's fine.  But all of a sudden, my batch plotting has started to only plot in color even though I am selecting my saved plot style.  Any ideas on how to fix??  So annoying.
@keedesigns - topic title has been adjusted for better findability. Original '[Re: Apply Plot Style to Batch Plot pdf/ Batch plotting has started to only plot in color- AutoCAD LT ]'
pendean
Community Legend
Community Legend
@keedesigns A CONSISTENT PUBLISH RULE OF THUMB:
1. Start PUBLISH command from a drawing that is not part of the publish set, but is configured with all your possible sheets and plotter options.
2. Bring in all the other drawings/tabs to be published.
3. Import the pagesetup desired from the template file (in your case, one set up for exacting desired output).
4. PUBLISH.
Just remember, CTB plot style tables have no effect on DWG files with TRUECOLORS or ones set up to output to STB files only.
paullimapa
could you do the following screenshots & share them here:
1. Plot window when you do a single page print
2. Publish window when you batch plot
Paul Li
IT Specialist
@The Office
