BATCH PLOT ISSUES
BATCH PLOT ISSUES
jrettew7C628
Message 1 of 12
BATCH PLOT ISSUES
jrettew7C628
MY BATCH PLOT STARTED ACTING WONKY.
IT HAS A TENDENCY TO PLOT THE FIRST PAGE 2-3 TIMES AND MISSES OTHER PAGES IN THE BATCH! WORKED FINE BEFORE. DO NOT KNOW WHAT CHANGED OR HOW TO FIX IT?
Replies (11)
Message 2 of 12
pendean
Community Legend
Community Legend
Ia the problem just limited to this one set? or all sets?
What are you publishing to?
What is your LT version as listed in ABOUT command?
Message 3 of 12
jrettew7C628
not sure what you mean by "sets"
i usually start with a template for drawings and simply copy additional "pages" as needed
Autodesk AutoCAD Inventor LT Suite 2016
plotting to Ricoh MP W7100 PS this once worked and now it completely jams up machine!
plotting to pdf is fine
Message 4 of 12
pendean
Community Legend
Community Legend
To use batch plotting, you have to select a set of "pages" to do that: that is what I am calling a set.
So is this error with this one set you batch plotted? Or does it happen to all other sets?
Inventor LT Suite is two separate software packages, so you are using an old LT2016 version.
So what is new with your setup?
Did you get new templates you are starting with?
Or is the Ricoh new? Or did you install a new driver for the Ricoh?
New PC?
Let us know.
Message 5 of 12
jrettew7C628
gotcha on the "set"..
it happens all the time now with plotting to the printer.
NOT pdf--strange
Nothing is new on my end, however the IT "gurus" switched something in our system. (no idea what the heck they did....) I dont recall if it coincided with that...
If i "call up" each page and "print" it, it goes lickity split. but batch plotting, it just gets stupid and bogs down my computer and everything i.e. cannot switch programs or anything other than sit there and wait for it to finish
Message 6 of 12
pendean
Community Legend
Community Legend
Find out what IT changed: it might be worth knowing for sure.
Batchplotting fails like you describe if the pagesetup did not apply to the page you included in the set: this could be who you are selecting/choosing the pageasetup from your template, or a mismatch with what the layout is.
Can you walk me through your process step by step?
Message 7 of 12
jrettew7C628
Basically i have a new drawing.
This drawing consists of workspace and one paper space (which has our title block on it)
If i need additional paper space, i simply copy and rename existing as a new page.
Should that not work?
Message 8 of 12
pendean
Community Legend
Community Legend
"new drawing" still doesn't take away from the cause of the issue: show us, post your ready to PUBLISH DWG file and your PUBLISH parameters for all of us to see for ourselves.
Or do you just need to turn off background publishing in AutoCAD?
Message 9 of 12
jrettew7C628
HERE'S A THINNED OUT FILE
HAVE AT IT! HAHA
Message 10 of 12
pendean
Community Legend
Community Legend
Thanks for the single layout file: it PUBLISHes and PLOTs just fine as a 24x36 PDF as you have the pagesetup in that layout defined.
Do you need to post a multiple layout DWG file(s) that exhibits your problem instead?
Message 11 of 12
jrettew7C628
I have no trouble plotting or publishing to PDF either. It's just going directly to the plotter that screws it up.
It must be a driver or communication problem.
Maybe I just need to change my publishing habits.
Message 12 of 12
pendean
Community Legend
Community Legend
I don't have your plotter, I'm sorry: if the issue is there you can PUBLISH to PDF first then print to the plotter as a workaround.
