Hello all,
I'm trying to autoload lisp's like I do with AutoCAD.
For AutoCAD, I know the acaddoc.lsp file goes here: C:\Program Files\Autodesk\AutoCAD 2024\Support
But for AutoCAD LT I do the same. I put the acadltdoc.lsp in C:\Program Files\Autodesk\AutoCAD LT 2024\Support
It does not load. Did the directory change? what am I missing? I rather do this than go into AutoCAD and specify it in the CUI.
Thank you!
ACAD = AutoCAD, all variants of "full"
ACADLT = LT versions of AutoCAD exclusively.
if you never forget those, you'll always catch the correct file for the correct program all the time.
After more digging, the acadltdoc.lsp goes here:
C:\Program Files\Autodesk\AutoCAD LT 2024\Support\en-us
@anieves228 wrote:After more digging, the acadltdoc.lsp goes here:
Not quite, the 100% correct answer is... you can place those files anywhere you want as long as you list it here and put it on top of all the others. Here is how we do it in our office because we like to always know where our personal content always resides for all of us in one single spot
