AutoCAD2009LT 32 bit doesn't work on my new Windows 10 64 bit
blazeengineer
blazeengineer
Community Visitor
Community Visitor
How can i use my AutoCAD 2009 LT (32 bit)  on my new laptop with windows 10 ( 64 bit )
Does AutoCAD 2009 LT (32 bit)  work on  windows 10 ( 64 bit ) ?
J.FOCHT
Hello @blazeengineer,
AutoCAD 2009 LT was designed to be run on the Windows Operating Systems XP and Vista. Therefore, chances are it will not wok. As an option, you could download a trial of the software and test to see if it will run on your system before purchasing anything.
Hope this helps!
If this helps you then hit the LIKE button or mark as an ACCEPTED SOLUTION!
Thank You!
Jonathan Focht
pendean
Community Legend
Community Legend
Your version of AutoCAD/LT is not supported in Win10 as explained here http://autode.sk/1IY4C2X
What that means is the following: if it used to work and now does not, or if you are trying to install it but you cannot get it to install, or any other related issue that involves your older AutoCAD/LT version and Windows10, Autodesk will in no way shape or form ever get involved in finding out why and will never plan on issuing any fixes.
For most users these free tips help a lot http://www.howtogeek.com/228689/how-to-make-old-programs-work-on-windows-10/
For others they roll back to an older Windows OS and hang on tight to it for life.
For others still they purchase a fix from these folks http://www.longbowsoftware.com
As far as Autodesk is concerned, you will need to subscribe to a newer version of LT.
Hope these help.
