Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
AutoCAD LT Forum
Autocad window stays minimised and won't show
1 REPLY 1
rdellorcoVW4WC
384 Views, 1 Reply
Hi, I'm having a major issue with Autocad LT 2024 and I'm not able to solve it.
Last week the autocad window keep staying minimised and I cannot find a way to show it again.
I'm only able to show half command line, as shown in the picture below.
I have tried a clean uninstall but I have an old Autocad 2012 that I use as backup that I would like to keep and do not uninstall, so I'm not sure I can do a clean unistall at all.
I've reinstalled autocad lt 2024 and it has the same issue.
Autocad people, do you have any suggestion?
Thank you very much
Tags (1)
1 REPLY 1
Simon_Weel
in reply to: rdellorcoVW4WC
Try 'resetting' AutoCAD by renaming registry key hkcu\Software\Autodesk\AutoCAD\R24.3 and rename folder <appdata>\Autodesk\AutoCAD 2024. Then start AutoCAD and it should re-install the user files and settings.
Technology Administrators
