AutoCAD LT Forum
Autocad window stays minimised and won't show
1 REPLY 1
rdellorcoVW4WC
345 Views, 1 Reply
Hi, I'm having a major issue with Autocad LT 2024 and I'm not able to solve it.
Last week the autocad window keep staying minimised and I cannot find a way to show it again.
I'm only able to show half command line, as shown in the picture below.
I have tried a clean uninstall but I have an old Autocad 2012 that I use as backup that I would like to keep and do not uninstall, so I'm not sure I can do a clean unistall at all.
I've reinstalled autocad lt 2024 and it has the same issue.
Autocad people, do you have any suggestion?
Thank you very much
Tags (1)
1 REPLY 1
Simon_Weel
in reply to: rdellorcoVW4WC
Try 'resetting' AutoCAD by renaming registry key hkcu\Software\Autodesk\AutoCAD\R24.3 and rename folder <appdata>\Autodesk\AutoCAD 2024. Then start AutoCAD and it should re-install the user files and settings.
Technology Administrators
