Autocad PDF Drivers has a PDF Exploit causing email servers to flag as SPAM
gusk
Message 1 of 16
gusk
I have been trying to email a client all day with a PDF file I created using the AutoCAD PDF drivers.  Each time I emailed the file, I would receive an automated message from Microsoft (client's mail server) saying my email was flagged as spam.  The client's IT service emailed me the following explanation:
This message is being blocked because it has a PDF Exploit in the attachment.  Here are the details on the exploit from NIST:  https://nvd.nist.gov/vuln/detail/CVE-2018-12798
Here are the details from Adobe on how to fix this issue, you will need to update Adobe:  https://helpx.adobe.com/security/products/acrobat/apsb18-21.html
My Adobe Acrobat software is current.  I suspect the problem is the AutoCAD PDF drivers associated with my AutoCAD LT 2018 software (which is also current/Updated) allows this PDF Exploit.
Please advise how to address this issue.  Thank you.
Replies (15)
Message 2 of 16
Effective August 10, 2018, we have had the same problem all day. Logs indicate the attachment is being flagged for Pdf.Exploit.CVE_2018_12798 that was released July 20, 2018. It is possible Microsoft just applied the detection signatures to our email gateway. We have found that Re-saving the PDF using the Print option will strip the attributes causing the false Virus trigger and the email can be successfully resent with the new file.
Word Arounds:
       For non AutoCAD users,
  • If you get a non-delivery notice,
    • Open the PDF
    • Click the Print icon
    • In the printer pull down menu, select any PDF writer available in your list
    • Click Print
    • Type in a new file name
    • Click save
    • Now you can resend the email with the new attachment and it should go out fine.
For the AutoCAD users that create the PDF:
  • Until a fix is applied, this creates a clean PDF that will deliver through Outbound Email filters.
    • click File > Print > Plot > PDF
    • Type in the file name
    • Click Save
Message 3 of 16
toddttucker68
I am having the same issues with one of my clients, as well.  When I use the DWG to PDF.pc3 plot files and plot a single sheet at a time (one sheet into one file), I have no issues (High Quality, Smallest File, Web and Mobile etc).  It is when I try and publish the PDF sheets into one file, that they get the PDF.Exploit 2018 flag.
Message 4 of 16
cforrestdrafting
I have been having the same issue since Friday, 8/10. All of a sudden any of my PDFs printed from AutoCAD are being flagged by my email server as a virus. A scan showed that they all have the 'pdf exploit.cve_2018_12798...'
I am able to re-print the PDF from Preview and send it through email, but this is time consuming and more than doubles the size of the PDF.
I print most of my PDFs through the publish function with multiple layouts to one PDF, is there a work-around for this yet??
AutoCAD LT 2018- Up to Date
iMac 5K- High Sierra 10.13.6
Message 5 of 16
toddttucker68
I just contacted my reseller, and this is the first he has heard of it.  He is contacting Autodesk, but since it is not a critical issue, he said it may take them a week or two to address.  As I stated before, single sheet PDF files do not create an issue.  It seems to be localized to the publishing application only (multiple sheets within a single file).  I am having to publish and then reprint using google docs within my google drive account.  This seems to remove any flags to the "PDF-exploit" status.  The only other work-around would be to print each individual sheet, and use a PDF program to combine the files together into one PDF file.   I hope this is addressed sooner than later, as it is a time-consuming process.
Message 6 of 16
gusk
Thanks Todd.  I think Glenn's solution provided previously offers the easiest solution, especially when it comes to generating PDF files that include multiple sheets.  This way you can let autocad generate the flawed multi-sheet file, then reprint the same file again using your alternate PDF software product to eliminate the issue.
Message 7 of 16
toddttucker68
Thanks.  That is what I am having to do.  I was making the suggestion that there may be some products out there that combine multiple files into one file, as an option.  When I print out the single sheets, there is no issue with the file...only on multi-sheet files.
Message 8 of 16
toddttucker68
I agree with you.  I just did a test, 1) reprinting the published file, and 2) printing each individual sheet and then merging in google drive.  The reprinted file was 75% the size of the merged file.  I will reprint until Autodesk or MS can come up with a solution.  Thank you for the suggestion.
Message 9 of 16
john.vellek
Hi @gusk,
Thanks for bringing this issue to my attention.  We are actively investigating this issue and I hope that I can offer some more details quickly.
In my personal research on this issue, (one site I used for information) this vulnerability first surfaced in May.  Apparently some people have been able to resolve it  by updating their PDF Readers to the most current version.  It appears though that there are some Anti-Virus solutions that are still tagging PDF files that have this vulnerability.
Some users have indicated that Publish vs Print have different results with this problem  but I suspect that it is actually the page setup and plotter configuration that gets used by either command that will dictate the result.
Printing  the PDF to a new PDF file is a great workaround if you are facing this situation.
I will follow up when I have more solid information.
Thanks to everything experiencing this problem for your patience.
John Vellek
Message 10 of 16
toddttucker68
I personally printed single sheets using all PDF options (High Res, Mobile and Web etc), and had no issues with them.  When I selected more than one sheet and chose Publish, with any of the aforementioned PDF options, it showed up as having a virus.
Todd
@john.vellek wrote:
Hi @gusk,
Message 11 of 16
john.vellek
Hi @toddttucker68,
Thanks for the additional information. When you use Publish, are you using the Plotter Named in Page Setup option?
John Vellek
Message 12 of 16
toddttucker68
Normally, I select PDF, and then Publish (my default is a page PLT file).  But when I discovered the issue, I went to my page manager and selected PDF as the default, and tried to publish it that way (using the page default), and still had the same results.
Message 13 of 16
 @john.vellek Hi have you learned any more about this issue and whether a solution is available?  I believe this thread is marked "Solved" but it really only has a workaround so far.
Mark
Message 14 of 16
john.vellek
Hi @Anonymous,
I believe this issue has been resolved by new antivirus definitions being release. If you are experiencing this issue make sure that your definitions are fully updated.  Please let me know what security application you are running and the definition version.
John Vellek
Message 15 of 16
gusk
Hi John.  I believe either the PDF drivers in autodesk software need to be updated or email servers will need to allow PDF files with the exploit to continue to be received and directed to their intended email users.  The email server that services my client that flagged my files was part of Microsoft 365.  Unless Microsoft is going to revert back to their former server policies, I see this problem will continue and grow.  Hopefully you have already spoken with representatives from Microsoft to get their thoughts and perspective.  If you have, I'd be very interested in hearing more.
In time I suspect other email services will adopt similar policies and you will see more complaints/issues.  In the meantime, I'll continue to reprint PDF files since that is the best band-aid suggested to date.  Hopefully there will be an autocad update that includes updated PDF print drivers issued soon.  Thank you.
Message 16 of 16
john.vellek
Hi @gusk,
I use Office 365  for mail services and none of my PDF tests have failed to have been delivered.  I suspect that this might be the definitions being applied to the one server you hit in the farm.  To my knowledge, definitions have been updated so email servers with current definitions should not be blocking these files any longer.   If you are able to show otherwise, it would be helpful to continue the team's efforts to get the issue resolved.
John Vellek
