AutoCAD LT - Tool Palettes
jspotter
Observer Observer
jspotter
Observer
Observer
I have had every AutoCad LT issue from 2010 to 2022, and for reasons unknown to me the 2021 and 2022 versions will NOT load the Tool Palette on screen. The tab illuminates as to say such has happened, but the screen is baren of the actual Tool Palette window/folder. To be specific, the path is View>Palettes>Tool Palettes= zero display????
I have checked my older versions and work in 2020 when I need it, but this is seriously annoying. Does anyone know why this is happening?
John P.
[ The subject line of this post has been edited to include the product name by @handjonathan ]
user181
Have you checked to see if its behind your docked properties palette?  You can undock it and move it to see or you can just grab the entire autocad window by holding the left mouse button down on the title bar that says autodesk autocad lt and drag the cad window around and see if its behind anything.
jspotter
Observer
Observer
Hi 181,
Thanking you for your reply and suggestion, but unfortunately, those avenues have been explored and unyielding. I just wonder if there is some sort of pathway discrepancy that arose from 2021 onwards. My PC runs on Windows 10 pro.
Much thanks.
h_s_walker
Have you used a dual screen setup at all?
Howard Walker
Left Handed and Proud
pendean
Community Legend
Community Legend
Your TP is off-screen or hiding, nothing more. Since you are not sure what triggered it, did you see this and try everything to bring it back https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Palett....
A reset of LT2022 may help for an alternate fix as well as a full removal and reinstall of the application.
BTW most of us in here replying to posts have also user LT from V1 through LT2023 today, there is nothing unique about LT2022 when it comes to TPs.
