How to buy
Privacy | Do not sell or share my personal information | Cookie preferences | Report noncompliance | Terms of use | Legal | © 2025 Autodesk Inc. All rights reserved
I just noticed this the last few days. When I open autocad or even if it has been open and I go to the start screen, the list of drawings shown is not listed in LAST SAVED order. It is listed in LAST OPENED order. I know this wasn't the case before, but I don't know how this could have changed.
Does anyone know how I can change it back? I know its probably super simple and I'm overthinking this.
Thanks!
@Anonymous hello, you can refer to this LINK. thanks
as seen from below image you may need to increase the value . (valid values are 0-50)
Imad Habash
You are correct. Please take a look and let me know if anyone else has this issue or knows where to change this setting. Thanks!
The only settings available are the ones below
Howard Walker
That is not a screen i have in LT 2018.
Click on the big red A in the top left hand corner
Howard Walker
No I understand exactly.
You want your files to appear in last saved DATE ORDER (most recently saved at top), unfortunately that doesn't look like a setting in AutoCAD
EDIT: Looks like "BY ORDERED LIST" is supposed to be date last saved.
Howard Walker
It has nothing to do with productivity as it does with making things easier I guess. They developed this start tab and granted not every new idea is a good idea, but I got used to using it.
I can definitely set the variable to 0 so there is no start tab, but that's a workaround. If I can get it back to the way it was before this happened, why not determine the cause and then change/fix it? That's all I am saying.
I am not a fan of the workaround when the "fix" exists.
How to buy
Type a product name
