In full AutoCAD I use reactors to automatically set the active layer depending on the command. This is tied in to our layer standards. I realize I can set Dimension, Text, Hatch, Centerline, and Centermark to default layers in AutoCAD LT, but with our standard layers I have other commands that go on specific layers.
Is there a way to use Diesel to make a layer active per command, and then go back to the previous layer which was active prior to the command?
-Chris K
