AutoCAD LT - Proxy entity to Mtext
RonTUKPC
RonTUKPC
Community Visitor
Community Visitor
Is there a tool that converts text features stored as proxy entities to mtext entities?
I'm aware that I can explode the Proxy Entity to convert it to an MTEXT feature, yet, this is not the output I want, because it takes a text feature for a dimension 32.35' and separates them into individual characters ("3", "2", ".", "3" "5")
I would rather go by way of preserving the string of the text (32.35'  > 32.35').  These are dimension features that were added that may have had a custom tool create a curvature effect to have the dimension feature align itself to the curve of the line it represents.
Is there a tool that can convert the Proxy entity feature to an MTEXT feature without exploding it into separate characters?
[ The subject line of this post has been edited to include the product name by @handjonathan ]
h_s_walker
Not in LT, maybe in full AutoCAD.
Howard Walker
Left Handed and Proud
pendean
Community Legend
Community Legend
@RonTUKPC If that was created with ARCTEXT in full AutoCAD, you will need to be using LT2023 to access it/edit it within the same limitations present in full AutoCAD too.
If something else created it, the content/file creator may be able to use EXPORTTOAUTOCAD command to help you out: you'll have to test and confirm (if that's not how you've done it so far).
HTH
handjonathan
Hi @RonTUKPC
Thanks a lot for posting your question to the forums!   Have the solutions suggested by @pendean & @h_s_walker helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
