AutoCAD LT - hatches are bleeding through problem
jeff
jeff
I made this drawing with various hatches.  I am using this drawing to make brass etches for a project.  The etcher states that the hatches are bleeding through.  This image shows the original drawing.
This drawing shows the bleed through when I select one area.  Can anyone explain to me why this is happening and how to fix it please?
thank you,
Jeff Otto
[ The subject line of this post has been edited to include the product name by @handjonathan ]
pendean
Community Legend
Community Legend
based on your images alone, you do not have a well defined boundary to contain your hatches.
Draw the outline you want and use it in HATCH command instead of just selecting an area.
jeff
Thank you,   I will try that.  I attached a copy of the file I took screen shot on.
Jeff
pendean
Community Legend
Community Legend
Thanks for the DWG file: you appear to already have the boundaries drawn
so you them instead of just clicking inside your busy areas
