AutoCad LT export types compatible with TOOLPAth V 2.9.03 on a CNC machine
What types of exports are available on AutoCad LT ?
Does the DXF export function have more than one type ?
What export forms does AutoCad LT have that are compatible with TOOLPAth V 2.9.03
on a CNC machine. ?
Which version of AutoCad Lt would have that compatibibilty  ?
[ The subject line of this post has been edited for clarity by @pendean Original: AutoCad LT export types ]
pendean
Community Legend
Community Legend
Greetings @Anonymous
Google Search taps LT's HELP files and says...
https://help.autodesk.com/view/ACDLT/2023/ENU/?guid=GUID-A72DB257-3410-4792-B548-6B9FC1DED72B
What file formats does your TOOLPAth V 2.9.03 and CNC accept? That would be something you need to know for sure from their support folks and product HELP files.
cadffm
-What types of exports are available on AutoCad LT ?
https://help.autodesk.com/view/ACDLT/2020/ENU/?guid=GUID-A72DB257-3410-4792-B548-6B9FC1DED72B
plus all you can create by (installed)  printer drivers, like PDF JPG ... and command PLOT
- Does the DXF export function have more than one type ?
Different DXF formats, dxf2018 is currently the newest, dxf12 the oldest.
-What export forms does AutoCad LT have that are compatible with TOOLPAth V 2.9.03
I don't use TOOLPAth, but I think the answer is: DXF, if toolpath can read in DXF
but what do you want to export? Simple lines and circles = 2D contours?
For 3D, take a look to Autodesks FUSION360
-on a CNC machine. ?
DXF
-Which version of AutoCad Lt would have that compatibibilty  ?
All
Sebastian
