AutoCad LT changes symbol font from a AutoCad file.
adasilva9G6GJ
Observer Observer
adasilva9G6GJ
Observer
Observer
I am a drafter and I use AutoCad 2021. The engineer uses AutoCad LT 2021.
I use the Center Line (CL) symbol on a MText box. Works just fine.
The issue is: Opening the DWG using AutoCad LT, just the symbol changes the font on the MText box.
And it gets worse: you can't change the font. I tried select the text and change the font/style, but the symbol still on the same way.
Booth AutoCad LT and AutoCad are updated.
Booth PC's have the font installed (romans).
pendean
Community Legend
Community Legend
Never seen the issue: can you share that DWG file here? Most of us have both programs and the stock font.
OR... One you you has a different definition of that font, then are only identical by name.
Or that symbols is from a different font altogether, one of you have it, the other is getting a substitution.
