AutoCAD LT - Arc-Segments of some polylines are displayed incorrectly
l_neukom
l_neukom
I have this annoying bug, where the arc-segments of some polylines are displayed with an offset (see screenshots). The handles are displayed at the right position (where the polyline actually is). The file also prints just fine, without any offsets.
The bug seems to occur only in larger drawings, but I cannot reproduce the misbehaviour consistently. Drawing a new polyline usually works as expected.
[ The subject line of this post has been edited for clarity by @handjonathan Original: Arc-Segments of some polylines are displayed incorrectly ]
cadffm
I can't see a bug, just the performance saving feature (adjust by viewres)
Or is it not showing properly after using REGEN command?
Sebastian
l_neukom
The issue cannot be fixed with the REGEN or REGENALL commands.
Viewres is set to 1000, which is enough for me. Some polylines display correctly, others don't.
pendean
Community Legend
Community Legend
What you want is apparently not working for your current system sadly: go higher, 10000 works just fine for all of our offices users (20000 is the maximum). Unless you have other underlying incompatible hardware issues on your PC that you did not mention, is that the case by chance?
cadffm
If Regen doesn't help, it is another thing.
Please share sample file withis THIS pline.
Is it the same without hardware acceleration(graphicsconfig)
in 2dwireframe as visualstyle?
Sebastian
